a little problem with sr20det
black240sx96
Car: cars girls motorcycles and bmx freestyle
ok. im having a little problem with my sr20 swap....i got the car to idle but after about 2-3 mins the car will cut off on its own then its a bit of a pain to get to turn back on....could it be because im using a stock US 96 240sx fuel pump and not the walbro 255 ??
Silvia007
Car: 93 Nissan 240SX SE Fastback
Sounds like a water temp sensor. One for the ECU not the gauge.
black240sx96
do you know what the voltage is supposed to be and which wire is it...i have wiring diagrams but they all say something different
180fan
Car: 89 fastback
check the resistance across the sensor
