A little problem
Miro1
Car: Nissan Maxima
While jumpstarting a car someone reversed polaroity.Now the car starts and runs but when I turn a key toon position control lights do not come onI have foud burded small wire of the battery terminal +after rewiring it back works fine but when i start the carthe wire gets very hot ,so there must be a short somewherebut why only when the engine is running?.Miro
Modified by Miro1 at 6:17 AM 1/31/2006
Miro1
Car: Nissan Maxima
It's me again I am learning how this forum works
maxhopper
Car: 02 Maxima SE 6spd
If that's the case, it sounds like it would have to be a short after the ignition circuit.
audtatious
Did you use the same gauge wire when you replaced it? Did you replace the whole wire or just the burnt section you found?
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Sounds like it might have been a fusible link?
Miro1
Car: Nissan Maxima
Sorry I don't even know what is a fusible linkCould You please give me more details.
Miro1
Car: Nissan Maxima
I have used smoller wire to be safe,but there is a short for shure the insutation starts melting and gets very hot.
audtatious
I take it smaller wire = smaller gauge (bigger physical wire than factory).
You are going to have to trace that wire back. It is grounded somewhere. Not fun, but that's about all you can do.
