;oP Getting pissed (and having a long conversation with the dealership owner) that the workers at the dealership where you bought the car don't seem to be taking your car seriously because it is themed after a WWI biplane, while the workers at the other dealership (owned by same person) do and complaining that you can get good service at the latter, but not the former... THAT sometimes works to one's advantage... ;oD especially after you prove beyond a reasonable doubt that YES, they did indeed place the front license plate bracket on crooked. ;oPFrancesTheMute wrote:but blowing up at them rarely helps. They could care less about you or your car.
You might want to try that out before you count on it. I've had 3 of those small compressors that plug in to the cig lighter, and not one of them had enough power to inflate a car tire. I ended up spending $130 for a good compressor with a reservoir from Sears. You can't carry it around in your car in case of emergency, but it will do car tires with no trouble at all. It'll also run really cool air tools.srellim234 wrote:I picked up one of those really small air compressors, the kind that comes in that little Slime brand flat tire repair kit at Pep Boys. The compressor plugs into the car's power adapter and fits in the space on top of the spare tire rim and under the floor of the cargo area. That way the compressor is always with me in the car and storage space in an apartment is not an issue.
I paid $25 for my tire inflator...hmmm.matt_a wrote:That would tick me off, but that has always been a pet peeve of mine. I don't like people messin' with my tire pressure. Many mechanics will just whip out a $1 pencil-type gauge and adjust to what the door badge says. For one thing, those cheapo tire gauges can be very inaccurate. I have a dial gauge that is much more precise. Secondly, the door badge is meant for the OEM tires that came on the car. If you have changed to a different tire and rim size, that info no longer applies. And even if you do still have the factory tires, I have always preferred to run my tires at a little higher pressure than the door says. Most of the time you will notice that the door badge pressure is a lot less than what the tires themselves list as the max. You can change my oil, top off my fluids, and check my air filter...but keep your paws off my tires!
nissantech06 wrote:
And to the person above who says THEY don't give a crap about you OR your car...I know I can only speak for myself, but I've fixed many things nobody has asked me to because I know that the customer will appreciate it
jfanaselle wrote:When I purchased my car, I checked the tire pressure the very next day and every single tire had at least 45 PSI in them. One of them actually had over 50 PSI. I was really mad and even called the dealership to complain. The sales person used the excuse that the factory filled them up that much and the dealership didn't even check them. Now, when I go in for service, I tell them not to touch my tire pressure and I check it myself once I get home.
Hmm...I must have just had really bad luck with mine. None of the ones I've owned had enough power for car or truck tires. They would get them to about 20 psi and then just run and run with no improvement. Oh well, I'm glad you have a good one!srellim234 wrote:Matt_a - I use that compressor all the time. I've used it for a long time on my cars and other cars as well, my bicycle, golf carts with inflatable tires and sports equipment. It's been great.
I also carry a combo jump starter/compressor in my Buick. I can't tell you how many times I've used it to aid other motorists. I've only had to use it once on my own vehicle, but it was worth it's weight in gold when I needed it.
Or the person who did the PDI didn't adjust the air pressure in the tires...I have seen it happen many times on dealer trades.07Vsdn wrote:actually, that is quite likely. to prevent flat spots on vehicles that sit for long periods of time the tires are often over-inflated.
Well you are a rare breed and I thank you. This is just my personal experience dealing with the dealership in Bakersfield. They didn't give a rats *** about my car till I spoke to the manager and informed him I worked for Nissan. That usually put a bug up their *** and made them clean up their act.nissantech06 wrote:And to the person above who says THEY don't give a crap about you OR your car...I know I can only speak for myself, but I've fixed many things nobody has asked me to because I know that the customer will appreciate it
I want to keep my job AND I enjoy actually fixing people's cars. I work with a few people who are like I am. Not everyone is the same way (not caring) but I have worked with a few people who are. Hell, I had to put a window regulator in a Murano, I made sure that the glass was squeaky clean when I was done, I've also had porters wash the cars I've worked on.FrancesTheMute wrote:
Hmmm...I wonder how practical it would be for me to drive to Bartlett, IL to have my car serviced.nissantech06 wrote:
Well, technically, Elgin. I live 12 minutes from workmatt_a wrote:Hmmm...I wonder how practical it would be for me to drive to Bartlett, IL to have my car serviced.
