llamabeta wrote:I was just about to post about this as well. I have an S13 myself and all the parts needed except the e-brake assembly. I was curious if the spindles and hubs allowed the appropriate space and bolt holes to attach the e-brake assembly to the S chassis spindles?
Anybody have any info? I'm trying to find the e-brake assembly since it's the only part I dont have. I was hoping someone has tried this before I grab this piece and find it wont work out.
Yep it'll work. but it takes a lot of work.
What you'll have to do is remove the hub from the upright, and mount the e-brake assembly between the two. There are holes on the e-brake assembly for the bolts to go through, so everything swaps in perfectly.. Remember, this brake setup was used on some 240sx's in jdmland, so it's basically a bolt on affair...
However... splicing up the z32 e-brake to the 240sx lines isn't very easy... That's the part that takes a lot of work...
