get a wideband O2 sensor and make sure its not running lean, check the heat range for the plugs, and make sure the fuel pressure, etc to that cylinder is alright. (even if the plug looks good, it may be rich just enough to cause problems in racing conditions)
uh..other than that, did you notice any other signs of heat problems in the cylnider? are there any possible heat riser areas in the cylnider(valve, etc?) also, if you're allowed to, take the vhicle to a place that can dyno-adjust the timing and such of the engine and watch the wide-band o2 sensor at the same time, more power, safer
-chet
