WDRacing wrote:DUDE...use some friggin GRAMMAR!!!! Capital letters at the beginning of a sentence, a space after the end of each sentence so it doesn't look like one big friggin run on.
The R33 has two turbo's, it needs two because they are so small. Absolutely worthless on a KA24. If you meant the GTS-t R33, it has the RB25 and a single T3. That turbo will be much better suited for 250, but still pretty small IMO.
The SSAC Bottom mount mani has a T2 flange if you really want to try and use the GTR turbo. Or you can get a GT28 or similar, which isn't good but better then the GTR turbo.
Reguardless, take the time and post things correctly. This is a technical forum, not a cell phone chat session. We use grammar here cause we're all grown up.
Welcome to KAT BTW, this is definitly the right place to be if you want help in the horse power department. Try reading the FAQ at the top of the forum.
WD
Just for you i will stop being so lazy and type have way.
Sorry i meant to say r32. And i know what comes on the r33's. the 2 turbo's i got,are from a r32 gtr rb26dett. I will inclose a pic of this turbo. this turbos are not the stock little turbo's. When i got the turbos i was told they was hks gt2530's. But after looking into it,they was not. Come to find out they was turbo's of the r32 gtr that have had hks to4 compresser hosing pu ton them.they spool real fast and make good power. A freind of mine has one of them now and he put it on his ka. He put done 260 with the turbo at 8psi. Until he ran out of fuel. He told me he need bigger injectors.
This is setup now.GTR R32 turbo ( with HKS TO4 compressor housing) on X02 turbular bottom mount manifold. 4x Sr20det 370cc Walbro pump 15 degree of timing plugs gap at .29mm UR pullies, lightweight flywheel, and CF clutch 3" turbo back exhaust Greddy FMIC 8psi of boost controled by power enterprise hybrid gauge Apex-i AFC-II piggy bag to tune Z32 maf
My goal is only about 300whp and i believe this turbo will be fine.
And also dont talk to me like im a kid either,because im not.
Btw,thanks for the help guys.
