Post by catriona_moira » https://forums.nicoclub.com/catriona-moira-u227488.html Wed Nov 13, 2013 2:20 pm
Post by simmode1 » https://forums.nicoclub.com/simmode1-u73804.html Wed Nov 13, 2013 3:22 pm
Milton'Z Nissan'Z wrote:CORRECT....this is an S13, not S14.
Anyway, after some dis-assembly, the blower motor resistor is located on the side of the blower box assembly just above the blower motor. Remove the glove box to get to it. The blower motor relay is located behind the HAVC control in the dash, just behind and left of it. To remove the blower motor requires more dash assembly, or die grind a small notch in the side of the blower motor mounting plate and/or the right glove box mount bracket, which won't hurt anything and save a lot of work.
...just in case anyone else has similar issues.
Post by catriona_moira » https://forums.nicoclub.com/catriona-moira-u227488.html Wed Nov 13, 2013 3:42 pm
NICOclub's Nissan forums and Infiniti forums and all affiliated sites are the property of HDS Holdings, Inc.
They are independent publications and are not affiliated with or endorsed by Nissan or Infiniti.
Information Copyright © 2000-2026 by NICOclub, all rights reserved. Material may not be copied or reprinted without written permission.
