a little help please?
sjbsuperman1425
Car: 1989 Nissan 240sx
CA18DET
heres the deal..
my rear passenger side caliper leaks brake fluid. i talked to the guy at Advance Auto Parts (a friend), and he said that if i rebuild the caliper, that i need a brake hone for the cylinder, or it'll leak. should i just get the $5 seal kit and call it a day, or is he right about it leaking.
none of the write-ups have anything to say about honing so im just asking. Thanks in advance.
NISSAN240SX12
Car: 1993 NISSAN 240SX SE COUPE
1991 Toyota Supra
i had the same problem when i first bought my car. I bought the rebuild kit and used 1000 grit sand paper to clean up the cylinder. hasn't leaked in 5 years.
Shabbernigdo
eh i just went to napa and bought re man clalipers and turned in the old ones for the core charge. much easier.
sjbsuperman1425
CA18DET
NISSAN240SX12 wrote:i had the same problem when i first bought my car. I bought the rebuild kit and used 1000 grit sand paper to clean up the cylinder. hasn't leaked in 5 years.
did you use any special pattern when cleaning the cylinder with 1000 grit? im going to do this soon so i just want to be sure.
sjbsuperman1425
CA18DET
well the problem was that the piston was pushed out to far, and i just needed to push it back in. +1 for easy fix!
