A Little Help Here Please!
tarheel
Car: cars
OK guys and gals,I do not mean to bore the hell out of ya'll but I need a little advise . So here goes. I have a 89 240sx hatchback with 131K miles on it . It is burning oil it is either leaking by the valve seats or the piston rings. I would like to rebuild the engine and add a turbo to it ,but I am unsure on whether rebuild with stock parts (to save a little money ) or replace with H.P. parts. If i rebuild with stock parts will they hold up to the pressure of the turbo. I do not want to replace the engine with another one from a wreck or anything, i'll just use the engine thats in there. Has anyone out there ever done this before and if so what were the results. I am thinking that if it is the valve seals that are bad then i'll just have a valve job done on it . Or should I go ahead and replace the piston rings while I am at it ? What other parts should I replace ?
I really thank you all for being here to answer these questions
navysnail
you might have better luck if you put this in 240 technical section.
ill help you out with what i know, the stock parts should be ok, but i would go ahead and replace the valve seals and rings if your going turbo.
