A little help here please !
tarheel
Car: cars
OK guys and gals,I do not mean to bore the hell out of ya'll but I need a little advise . So here goes. I have a 89 240sx hatchback with 131K miles on it . It is burning oil it is either leaking by the valve seats or the piston rings. I would like to rebuild the engine and add a turbo to it ,but I am unsure on whether rebuild with stock parts (to save a little money ) or replace with H.P. parts. If i rebuild with stock parts will they hold up to the pressure of the turbo. I do not want to replace the engine with another one from a wreck or anything, i'll just use the engine thats in there. Has anyone out there ever done this before and if so what were the results. I am thinking that if it is the valve seals that are bad then i'll just have a valve job done on it . Or should I go ahead and replace the piston rings while I am at it ? What other parts should I replace ?
I really thank you all for being here to answer these questions.
Eastcoast Wildboy
Hey man http://www.raretrick.com if u want a stroker kit make ur car from a 2.4 litre to a 2.6 jun makes it and it runs great it has an 8.5 to 1 compression ratio. Perfect for turbo and it comes with everything u need to rebuild a motor. I would go with like a blitz turbo kit becasue tehre ball bearings are very quick spooling.
EastCoast240
Eastcoast Wildboy wrote:Hey man http://www.raretrick.com if u want a stroker kit make ur car from a 2.4 litre to a 2.6 jun makes it and it runs great it has an 8.5 to 1 compression ratio. Perfect for turbo and it comes with everything u need to rebuild a motor. I would go with like a blitz turbo kit becasue tehre ball bearings are very quick spooling.
Not to be a d!ck or anything but you should do a little more research before you start giving advice......whatever stroker kit you were looking at wasn't for a KA. There isn't one as far as I know.
Eastcoast Wildboy
Umm sorry i looked at it wrong i thought it was for the stock engine it was the 2.0 litre sr20 but there are internals in there for the ka sorry eastcoast240!! Not trying to be smart by apologising im an apologetic person i am always like this.
