A little help for a buddy of mine...
nametakennow
Car: '06 MINI Cooper S
He had a run in with a curb and after fixing that began working on some other stuff on his pureslow '88 Accord LX 5speed (yes, carburated slowness)...
http://www.3geez.com/showthrea...56103
Summary:Well, a transmission bolt has pwninated every attempt to get it off... meaning some tools and, yes, the leg of a workbench to which a WENCH was attached to. Soaked in tons of PB blaster and under 500lb/ft of torquination (I'm in the make-up-words-mood, shut up)... the ***** still won't come off, apparently. Anyways, if you were too lazy to click the link, you're gonna have to now cause I really can't explain it that well, seeing as I was not part of this car-fixing venture...
I say we get my other buddy's V8 Silverado and start pulling...
Mr1der
you try turning it the other way?
be careful or you might snap the head off...
nametakennow
Like he says in his thread, it ought to be turning the right way. If not, he just tightened the ***** out of it. If he goes back to turn it the other way, he may just snap something.
Altiman94
Car: 1989 Nissan 240SX
that's one crazy stuck on bolt. I was about to go to extreme measures today with the flywheel bolts on the free ka24de I acquired.
gabossie
Car: Your mom
Damn, that's one very stuck bolt. Get out the breaker bar and try the winch. The added leverage of a breaker bar is huge. Or go with the air chisel, seems to have worked for the other guys.
