A little help? CA18DE vs CA18DET cams?
cdkilla
Car: 2002 Subaru WRX (dd) 1990 240sx CA18DET. 2005 VW Jetta TDI (Wife's dd)
I may have mis-read and made a bit of a mistake on my rebuild...
I purchased a remanufactured head for my ca18det from alabama cylinder heads when I was rebuilding my ca and obviously being I'm stateside, I got one for the N/A ca. I had asked and made sure that the head was going to work. I didn't think much of the cams that came in the head :facepalm: So I put it together using the N/A cams.
My question is: Are the N/A cams different than the DET cams? I searched and couldn't find much for specs for the N/A cams.
Reason being: I have a wierd timing related(I think) issue. If I have it set to the factory setting, it stumbles around at lower rpms and then clears up around 2500. Seems to run good past there, although I haven't pushed it much. If I advance the timing a couple degrees it seems to run better at lower rpms and then stumble a little but not as bad at around 3500k.
I'm just kinda stumped. Don't really know where to go from here.
Thanks!
D_Stirls
Car: Nissan 180sx 1990 Ca18det
Here are the cam specs. The lift and duration are the same but the base timing is ever so slightly different.
JPN spec CA18DE S13...
In lift - 7.8mm
Ex lift - 8.5mm
In duration - 240
Ex duration - 248
In opens - 0 BTDC
In closes - 60 ABDC
In center lobe angle - 120deg
Ex opens - 59 BBDC
Ex closes - 9 ATDC
Ex center lobe angle - 115deg
JPN spec CA18DET S13...
In lift - 7.8mm
Ex lift - 8.5mm
In duration - 240
Ex duration - 248
In opens - 0 BTDC
In closes - 60 ABDC
Ex opens - 64 BBDC
Ex closes - 4 ATDC
Ex center lobe angle - 120deg
EURO spec CA16DE....
In lift - 8.5mm
Ex lift - 8.5mm
In duration - 248
Ex duration - 248
In opens - 15 BTDC
In closes - 53 ABDC
In center lobe angle - 109deg
Ex opens - 59 BBDC
Ex closes - 9 ATDC
cdkilla
Thanks I couldn't find anything when I searched. Makes sense that I'm having timing issues then... Any suggestions?
If I bought adjustable cam gears and compensated for the base timing difference in the exhaust cam would that work? Makes sense to me in my head but I don't want to make another mistake.
cdkilla
Can someone tell me if that would work or not? The only reason I'm not trying to source a different exhaust cam is the one in my head is freshly machined.
cdkilla
Anyone?....... Anyone?........ Bueller?........ Bueller?.......
cdkilla
Does what I'm asking not make sense or just no one is sure on an answer?
cdkilla
Well, I ordered a set of adjustable cam gears last night and I guess I'll see if I can sort this out or not. I talked to one of my buddies who's built a lot of dsm's and what not, he was pretty confident I should be able to get it dialed in.
