BBISHOPPCM wrote:I believe the car has a range of around 20-30 miles after the low-fuel light. If you are in an area with no fuel sources within 20 miles, You're probably in an area where you shouldn't be in the first place...
Out west there are quite a few stretches of interstate highway of 20-30 miles with no stops for services. For example, on the way to Vegas, once you pass St. George UT you will pass through a 30 mile stretch with not even an overpass. You will then reach ONE gas station. If its closed, you have another 20 miles till you get to the next stop. Once you pass Mesquite, service exits are spaced out about 15-20 miles apart. Not that there are service stations anywhere near the exit, most are several more miles away from the interstate. Its not a place to drive a car that is prone to breakdowns.
