I'd be really interested to know as well. I have been thinking about buying some split bushings from 4x4.com and just replaceing the bushings. Seems a goodly sized job without a press/torch to get the old ones out.Chuck Tribolet wrote:...RockAuto.com. They have non-Nissan (Dorman) rear trailing links for about $48. I've no idea what the quality is. Anybody tried these? ...
That's a good idea. Thanks!Chuck Tribolet wrote:You can probably use a bench vise to press in the new rubber bushings., but you'll need to fabricate something that pushes
on the outer metal part. Often an appropriate piece of plumbing works.
Chuck
I actually just spent 4 and a half hours yesterday tearing apart my rear end and replacing my trailing arms, both upper and lower, with dorman trailing arms. I ordered mine off Partsgeek.com and they were about the same price. ( for all 4 and KYB gas adjust shock i was 302.58). The quality of the dorman trialing arms doesn't seem to be anything above and beyond the manufacturers or any less quality. I have only had them installed for about 12 hours now but the difference is definite. And as far as money saving, a local shop wanted $1200 to do the job and it cost me only $360, because i bought all new blots and washers from nissan, as i expected from reading on other threads that breaking or cutting bolts was common.(mine came off with just a 36" breaker and a 6 ton jack and i didn't break any bolts or need to cut any off.)Chuck Tribolet wrote:I was chasing a new master cylinder for my 'vette, and the folks on CorvetteForum.com turned me on to RockAuto.com.
BTW, they have the easiest to navigate parts catalog I've dealt with.
Where can you buy these?cbogartjr wrote:I see Moog makes split polyurethane trailing arm bushings. They are $185.00 for a complete set (all 4 arms). I know Moog makes very good suspension parts. It appears the bushings are split for ease of installation. Has anyone tried these? I am considering purchasing a set. Polyurethane sounds good. Maybe they can be installed without a press. Interested in your thoughts...
04Chinook wrote:Where can you buy these?cbogartjr wrote:I see Moog makes split polyurethane trailing arm bushings. They are $185.00 for a complete set (all 4 arms). I know Moog makes very good suspension parts. It appears the bushings are split for ease of installation. Has anyone tried these? I am considering purchasing a set. Polyurethane sounds good. Maybe they can be installed without a press. Interested in your thoughts...
I was wondering the same thing. I wish there was another option other than 4x4parts. Their shipping rates to Canada are insane!Chuck Tribolet wrote:Are you sure the ones at 4x4parts are Moog? I bought from 4x4parts, and they didn't say anything and I came away with the impression they
were a house brand.
Chuck
