A hole in my understanding... camber and caster
Dattebayo
I just realized my understanding of camber and caster was about half incorrect. It would be really nice if the guru's here could enlighten me on the whole complicated explanation of it all.
I have found a few articles on the specifics, but they all seem to dumb it down a little making me ask alot of questions. Go ahead, shoot. Be merciless with the technical jargon and equations.
Nismo_Freak
Car: 89 Nissan 240SX
Dattebayo
I feel dumb now
Nismo_Freak
You setup camber by taking tire temp readings over the face of the tire. You dial in additional camber, or remove camber (total camber is always negative) to even the heat load over the face of the tire. This means the tire is being used to it's maximum potential.
Caster you typically want as much positive caster as possible before you have clearance issues, or you have poor steering feel (caster affects align torque).
The front of our cars will need a good amount of camber, the rear not so much, as it's a compromise point, and has a different dynamic geometry.
Well-done my friend.
Dattebayo
Nismo_Freak wrote:The front of our cars will need a good amount of camber, the rear not so much, as it's a compromise point, and has a different dynamic geometry.
I assume you mean 240sx's by "our cars". I don't drive one anymore...
My S12's rear has plenty of negative camber for some reason tho, I imagine it has something to do with the semi-trailing arm suspension I have back there. Too bad I cannot change it at all.
Nismo_Freak
Most Nissans have the same strut suspension in the front, and that's why it needs more front camber.
