Mustangs_Suck »
https://forums.nicoclub.com/mustangs-suck-u731.html
Tue Jun 07, 2005 5:21 pm
Only thing S14 engines have up on S13 engines (the DE series) are they usually have less mileage - if you were going to do a rebuild, it wouldn't matter whatsoever then - as far as I can recall at least.
Forgetting about the whole engine rebuild - you'd need to look into re-doing your cooling (intercooler, upgraded fans and radiator) all fuel support mods (bigger injectors, better fuel pump), tuning (Safc), a re-tuned ECU is a good way to do things too (does great tuning, and regulates fuel well too) - pricey, but helps out alot of crap. Upgraded MAF, exhaust system, all the piping for your intercooler and to run your turbo, turbo, turbo manifold, an upgraded clutch/flywheel (to hold the power you are making), boost/temp guages (so you know what's going on), boost controller , and brakes (if you start pushing higher hp, you'll start going faster alot faster, and you'll want to make sure you can still stop good). Of course this is pretty much a fully done car, if you were going for alot of HP, it's alot of stuff you'd need to be doing stuff safely. Of course if you are shooting for a lower hp goal, you won't need everything listed here - basics are the turbo, all the piping, manifold, exhaust system, upgraded fuel system, upgraded cooling system, and some way to tune it (SAFC).
Finally - definitley don't go with your "20 psi" goal imo. HP is where it's at, and from the HP goals you want to make - you'll be able to judge exactly what will all be needed to be boughten, done, and how much you're looking at spending.
I'm kind of a n00b to all this stuff too, but I think I pretty much listed off what you want to know accuratley - give or take some information.
There will be others that will be able to elaborate MUCH more than I - AZ,Fiznat, WD, and Structure come to mind right away - they've helped me out ALOT when it comes to my car.
Oh - and welcome to NICO
