I'll take this one on Simm.
WCC: Your statement about the plexi, lexan, lucite adding harmonic distortion is incorrect.
First. The door speakers should be crossed over no lower the 80hz. This is well above the range in which the door driver will be utilizing a large amount of excursion.
Lexan and plexi are both perfectly fine even for a sub as long as it is of sufficient thickness. You are assuming that someone is going to use 1/4 plexi. This is incorrect. For a door speaker 1/2 to 3/4 inch can be used with absolutely no ill effects. For a sub this would have to be thicker with cross bracing(that'd look cool), but again, it'd add no distortion as long as it is of sufficient thickness.
Third. Don't bring your arrogance on here. Both Simmsled and myself can single handedly kick your arse when it comes to electronics.
So don't come on here all high and mighty trying to blow your own horn.
Saying you're great means nothing, being told you're great means alot, but being talked about as being great means everything!
So it is not you who gets to choose wheather you are worthy. It is us.
Right now you are an unworthy individual that knows how to follow directions that are posted on
http://www.the12volt.com
