If I'm not mistaken the hks gt2510 is, in essence a full ball bearing version of the S13 Sr T25, thus....250hp max but spool is insanely fast.Chinamandrift wrote:ok ive read up that a GT25-10 will do up to 300WHP with the least lag
and if u dont want to max out the turbo go with a GT25-30... and that supposed to go up to 350WHP with the least lag possible
i read this somewhere, just checking to make sure the ca18det gUrus agrees with this.
whats a T3 or t3/t4 series turbo thats close to the same as the GT25-30? i plan to run a top mount but they only come in t3 flange.
im just looking for an upgrade with most response .....least lag possible...i guess you can say im looking for the disco potato turbo for the CA18DET
wouldnt a .48 be just a tad small for a t3/t04? (ive been thinking t3/t04e with like a .57ish turbine housing.. my quick skechy math says full spool a little under 3500 and more top end flow (more max power) than a .48OverBoosted180 wrote:Yeah! C-Rad is right. U can go the Gt route or if u wanna go a little bigger, a str8 t/3 or t3/t4 with a .48 back is perfect! Orrrrr......if you've got the bread to spare and wanna go all out..There's always the Gt35r
Highjackedc-rad wrote:Why not just get an S15 T28? I got mine for less than $700 shipped.
It's called torque, a 3.0L i6 NA car will instantly punch, our CAs build..r34 gtr wrote:i was kind of unimpressed with my gt28 at 17psi. ive found my car has enough fuel to do it safely, and itll make 17+lbs before 4k in 2nd-5th. kind of makes me think of what i need to do. if only i had the money for a built bottom end. its plenty quick, but i just know if its got the grunt. my dad's new bmw seems to have way more go.
