S14-NEO »
https://forums.nicoclub.com/s14-neo-u25945.html
Fri Sep 03, 2010 7:52 pm
Well I've sat on this info long enough so ive decided to share this hard to find info to help the newcomers out.......now dont get pissed because I'm too lazy to put up cool pics to make it idiot proof...you guys have got to figure some stuff ou ton your own...hehe
HERE IT GOES!!!!
TERM COLOR DESCRIPTION
1 B/R ignition signal power transistor cyl#1
2 R/W " " " " cyl#5
3 R " " " " cyl#3
4 O ECM & IGN coil relay control signal
5 W/B TACH signal
6////////////////////////////EMPTY////////////////////////////////////
7 R/G Ignition signal power transistor cyl#6
8 R/O " " " " cyl#2
9 R/L " " " " cyl#4
10//////////////////////////EMPTY/////////////////////////////////////
11 G/B AAC valve control signal
12//////////////////////////EMPTY/////////////////////////////////////
13 B/P Fuel pump relay control signal
14 G/R Air condition relay control signal
15//////////////////////////EMPTY/////////////////////////////////////
16//////////////////////////EMPTY/////////////////////////////////////
17 GY/L MIL lamp
18//////////////////////////EMPTY/////////////////////////////////////
19//////////////////////////EMPTY/////////////////////////////////////
20 GY/R Ign switch (start) signal
21 P A/C switch signal
22 Y/B check (diag start)
23 R/L TPS signal
24 W/L IGN switch (IGN) signal
25 BLACK Control unit ground
26 G P/S Oil press switch signal
27//////////////////////////EMPTY//////////////////////////////////////
28//////////////////////////EMPTY (NOT USED)///////////////////////////
29 Y/R Vehicle speed sensor signal
30 ? Headlamp switch signal
31 G/O Ign power supply
32 BLACK Control Unit ground
33//////////////////////////(NOT USED)/////////////////////////////////
34//////////////////////////(NOT USED)/////////////////////////////////
35//////////////////////////(NOT USED)/////////////////////////////////
36//////////////////////////EMPTY/////////////////////////////////////
37 ? Throttle open signal
38//////////////////////////(NOT USED)/////////////////////////////////
39 Y/PU Neutral signal (P/N switch)
40//////////////////////////EMPTY/////////////////////////////////////
41//////////////////////////EMPTY/////////////////////////////////////
42//////////////////////////EMPTY/////////////////////////////////////
43 BLACK Sensor ground
44 G crankshaft position sensor 120degree ref signal
45 G " " " " " "
46 R crankshaft position sensor 1 degree pos signal
47 R Turbo Pressure sensor signal RB25DET
48 L/B Power supply for TPS,refrigerant &turbo pressure sensor
49 B/W Rear DEF switch signal
50 GOLD heated O2 sensor signal (black plug)
51 ? TPS motor sensor signal RB25DET
52////////////////////////////EMPTY/////////////////////////////////////
53 ? motor throttle switch signal RB25DET
54 O/B MAF Signal (grey plug)
55 W/L MAF ground
56 PU engine coolant temp sensor signal
57 G/Y REF press sensor signal
58////////////////////////////(NOT USED)//////////////////////////////////
59////////////////////////////(NOT USED)//////////////////////////////////
60////////////////////////////(NOT USED)//////////////////////////////////
61/////////////////////////////EMPTY/////////////////////////////////////
62 GOLD Knock sensor signal 1
63 GOLD knock sensor signal 2
64/////////////////////////////EMPTY/////////////////////////////////////
65/////////////////////////////EMPTY/////////////////////////////////////
66/////////////////////////////EMPTY/////////////////////////////////////
67 W/B Control unit Power supply
68/////////////////////////////(NOT USED)/////////////////////////////////
69/////////////////////////////EMPTY/////////////////////////////////////
70/////////////////////////////EMPTY/////////////////////////////////////
71/////////////////////////////EMPTY/////////////////////////////////////
72 B/W Control unit Power
73/////////////////////////////EMPTY/////////////////////////////////////
74/////////////////////////////EMPTY/////////////////////////////////////
75/////////////////////////////EMPTY/////////////////////////////////////
76/////////////////////////////EMPTY/////////////////////////////////////
77/////////////////////////////EMPTY/////////////////////////////////////
78 G/O AUX ELEC fan relay cont signal
79 ? ECM,TCM,ABS integrated control signal
80 W/B BATT power supply
81/////////////////////////////EMPTY/////////////////////////////////////
82/////////////////////////////EMPTY/////////////////////////////////////
83/////////////////////////////EMPTY/////////////////////////////////////
84/////////////////////////////EMPTY/////////////////////////////////////
101 W INJ #1 drive signal
102/////////////////////////// EMPTY//////////////////////////////////////
103 W/R INJ#3 drive signal
104 Variable Air intake control sol valve signal
105 W/G INJ#2 drive signal
106////////////////////////////EMPTY//////////////////////////////////////
107////////////////////////////EMPTY//////////////////////////////////////
108 L Canister Purge control valve signal
109 W/G Control unit power supply (feedback circuit)
110 Y INJ#5 drive signal
111 ? fuel pump terminal voltage control output signal
112 W/PU INJ#6 drive signal
113//////////////////////////////EMPTY/////////////////////////////////////
114 W/B INJ#4 drive signal
115//////////////////////////////EMPTY/////////////////////////////////////
116 B/R Injector ground
117 LG/R Variable timing control sol valve control signal
118 LB/Y heated o2 sensor control signal
119///////////////////////////////EMPTY////////////////////////////////////
120///////////////////////////////EMPTY////////////////////////////////////
121///////////////////////////////EMPTY////////////////////////////////////
122///////////////////////////////EMTPY////////////////////////////////////
123///////////////////////////////EMPTY////////////////////////////////////
124 B/R Injector ground
