A (full) day with the NGK's
andbeyond
Car: 1993 Q45
well I replaced the spark plugs today
that and a fuel filter took me about 8 hours ( I know , 1st time)
this link helped a lot , a few differences with my 93 Q45, but helped
http://www.q45.org/sparkplugs.html
the bad news a few plugs were oil fouled and wet with oil
So , 2 questions
Am I correct in thinking valce cover gaskets are next?
and #2 this V8 has 3 tensioner pulleys correct ?
thanks guys
( only dropped / lost one bolt, but I had a spare in my bolt asst. bin)
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Yes to both.
Congratualtions!
superuber
When you say "oil fouled" do you mean oil on the electrode or oilon the porcelin? Oil on the porcelin is a leaky valve cover seal.You should have done them all in one swoop!
andbeyond
Car: 1993 Q45
superuber wrote:When you say "oil fouled" do you mean oil on the electrode or oilon the porcelin? Oil on the porcelin is a leaky valve cover seal.You should have done them all in one swoop!
yes thats what I'm realizing now, but yea, oil on the porcelin
I'm just debating if I now want to do the valve covers / gaskets
it seems if would not be that much harded than plugs
Rex
Car: None
Don't 90-93's not have pre-formed gaskets, but use RTV?
BTW, Wes left here just a couple hours ago after doing the NGK's in my 94 Q. Along with FUCA's & Tensions Rods.
Total time ~7 hours, but that included some post maint test drive with some ECU swapping to see if the knock sensors were being seen as bad by the ECU.
Raxephon
Car: '04 RX8...for the moment...
Rex wrote:Don't 90-93's not have pre-formed gaskets, but use RTV?
Yep, Liquid gasket/RTV.
I use the High-Temp Copper stuff.
