I was given a 89 s13 hatch, SOHC with 137269 miles on her. The interior is in great shape and the only rip/tear or crack is on the dash and small tear on the steering wheel. The previous owner, (original), had the engine run hot and replaced the water pump, head, head gasket, stock injectors, rocker rails and rocker arms and all vacuum lines. After putting $2600.00 into repairs he drove the car 1 time and after about 30 miles it quit on him. He asked me if I wanted it and I picked it up from the side of the road. His main problem wasn't the water pump. I found the new rocker arms seized on the exhaust side and from searching this forum, found the culprit to be the oil pump. I installed a melling oil pump and replaced the fuel pump with a walbro, (it still had the original and I figured why not). I also replaced both rocker rails and all the rocker arms. The old rocker arms were so seized to the rail that I had to cut them off. I installed a new battery and got her this past weekend and hit the ignition a few times to prime the fuel pressure. I then went all the way and she fired right up and idled around 1400rpms for about 15 seconds and settled in around 900. I pressed the accelerator and she revved without hesitation. I took my foot off the gas and just let her idle and after about 2 minutes the idle dropped to around 400 and she stayed there sounding ragged for about 15 seconds and then back to sounding normal. she sounded normal for another minute and dropped back to a very ragged idle again. it did this about 4 times before I cut her off and decided to finally introduce myself and ask some question. I have gotten this far with her by using the search and reading just about every tech post. I have tried searching, idles good then ragged" but haven't found anything. Is what she is doing called "limp mode"? Is she dropping into that then back to idling fine then limp....
Yall don't know how much you have helped me so far and I thank all of yall.
