Sygerwulf »
https://forums.nicoclub.com/sygerwulf-u1051.html
Fri Jun 11, 2004 12:16 pm
I need some help here. The other night on the way to work I hit a raccoon and slid off into a ditch, effectively bending the passenger side rear A frame (I am only assuming that's what it's called because it's an A shaped piece of metal that bolts the wheel to the frame).
Anyway, I found a replacement part, BUT I can't get it off of the damn car. All the bolts have been removed and the nut that connects it to the bottom of the wheel is off, but it just won't fall off the bottom of the wheel. It's completely loose and will pivot around on the bearing, but the damn thing won't come off. Is it possible that it's just rusted up? I need to know asap if anyone has had a similar situation like this or anyone that can help at all!
