ok i got a few things done. maf and o2 wires are extended, lengthened each injector wire so i can tuck them, and im almost done with the harness. i just have one more problem. im using the fr sport wiring guide
http://www.frsport.com/SR20DET....html
the last portion says to cut the plugs off the sr and use the ka ones but if you look at the brown wire it says to use any 12v switch or the main ignitoin wire. do i just solder both the main ignition wires together with the brown one? why cant i just solder it to the brown one on the harness or one of the ac relays that arent being used? they will give 12v correct?
and the unused wires i just tape off?
Modified by ZootedS13 at 9:11 AM 1/2/2010
