Postby
ZFreak »
https://forums.nicoclub.com/zfreak-u1508.htmlThu Nov 12, 2015 3:54 pm
Juuust about have the last of the little minor issues worked out and car is an absolute blast to drive now. I'll be making some new videos here soon!!! Got the new Richmond "Leader" Gears installed and the entire NA subframe and diff swapped over to the TT subframe with the R230 diff and Richmond 4.10:1 gears installed by EPR) (and full SPL suspension goodies front and rear with Powertrix UL coilovers w/swift springs, along with Inland Empire Carbon Fiber 1pc driveshaft)
I had some cold tune/cold starting issues in regards with how the fuel pump was wired, along with the IACV/AAC, but all seems to be well now. Resolved a grounding issue caused by the battery being located in the hatch (more grounding points from block to frame resolved it).
If you haven't seen any of my videos, here's a few:
Original walkthrough:
Version 2.0: (there will be a 3.0 soon):
Flyby Video of Version 1.0:
Flyby video of Version 2.0:
Reason:Fix video link
Postby
ce1lardoor »
https://forums.nicoclub.com/ce1lardoor-u256150.htmlThu Nov 12, 2015 9:23 pm
Man, that thing is gorgeous. Your engine bay looks so clean even jammed full as it is. Where did you get the adapters for your calipers? I may do the same with my project z.
