A few SR questions, PSI, harness etc..
Kenrik
Car: Nissan 240SX Coupe
Infiniti G35 Coupe
Nissan Versa Hatch
Ok so! here's what I need to know,
What's the stock PSI for a SR if you do a cold compression test? like for a brand new engine?
How good is 160psi all four on a cold engine?
If I get a SR transmission with all the sensors on it can I use a SOHC KA 5spd harness on it?
Thanks!
(yeah I did search)
ILikeMy240sx
Car: SR Power
This info can be easily found in FSMs posted in the sticky.
but anyways, standdard for SR engine is 156 on warmed up engine + WOT
So Id say 160 sounds pretty good
Kenrik
Infiniti G35 Coupe
Nissan Versa Hatch
ILikeMy240sx wrote:This info can be easily found in FSMs posted in the sticky.
sweet... the engine is supposed to only have 10k miles on it.
What about the KA harness?
ILikeMy240sx
Car: SR Power
I do not know about SOHC KA transmission harness and its similiarity to S14 KA trans harness..
BUT,
when I did my swap, I didnt even touch my trans harness. I just left it in there and when I swapped in SR trans everything just plugged right up. Few of the plugs were not used from KA trans harness. Different number of sensors in two trans.
Kenrik
Infiniti G35 Coupe
Nissan Versa Hatch
one more question I searched but could not find the info...
Are SR Automatic starters different from SR Manual starters?
