I have had my coils and icm fail at once, I feel your pain, as for your carb, I would check your firing order for the coils, your exhaust coil only fires when cold... once the engine is at operating temp only your ignition coil is firing. swap coil wires and see if it solves the issue
if it still does it then id check to see if they gave you a faulty coil and/or test the icm (ignition control module in the distributor) have you checked for vacuum leaks? as far as the brakes there isnt a Proportioning valve, sadly... but there is a nlsv (nissan load sensing valve) it regulated brake pressure by load tilt, should be on the frame near where the e-brake splits off. could be its malfunctioning?
