Nismo240sx1226 wrote:
#2I know a speedo recal is in order but what about retaining Cruise Control?
If you are retaining the stock rear diff ratio and using a Z32 trans, all you will need is a Z32 NA speedo sensor. Your speedometer will then function properly.
Your stock tach will work too, but that will need to be recalibrated.
As far as the ABS goes, that is an independant system, as long as you don't screw up the plumbing, it will work.
As far as the cruise goes, the above answer applies as well. Keep the factory wiring and use the factory cruise diaphram/cable. The cruise will work, but when you hit the "accel" button it will crack the throttle more than necessary, since the stock ASCD ECU is calibrated for an engine that makes a little bit less torque, lol.
