iKokomo wrote:1. My car has nitrogen tires, and I was wondering where can I fill the tires? (no gas station has nitrogen to fill the tires, just air) Can I use air in these tires?
why does your car have Nitrogen filled tires? are you 100% sure it does? thats a total waste for a Rogue. the only nissan car that has that is the GTR. the nitrogen doesn't get hot nearly as quickly as normal air does. but the rogue couldnt even if you tried get the tires to heat up quickly enough to expand and make a difference (unless you decrease air pressure which in result increases the contact patch, and over-flexes the tire = resulting in greater heat build up)
id suggest deflating your tires and refilling using normal air. Nitrogen filled tires are great for the racetrack, and thats it. i know when im racing my bike, i start out with about 24psi - and after a 10min circuit, i come back in and im at 32psi-36psi = because its the racing conditions; but on the street???
2. There is a ticking sound in the engine when the car first starts up (more when cold) that eventually goes away or at least is quiet enough that I do not notice it.
i did a mini write-up/explanation:
post6322338.html?hilit=coconut#p6322338
its very hard if your friend "
knows cars pretty well". its fairly easy if your friend is an automotive electronics specialist aka aftermarket installer. it might require installing one of your key's hidden in the dashboard(depending on car)
4. When do I know when it is time to change the battery? and what kind of battery should I get for my vehicle?
you will know by it starting slower than normal. sometimes the AWD light will ignite and not turn off(first sign of a dying battery because not enough juice to get the AWD system to do its checks the same moment the car is starting up). things like windows will roll up slower when the car is off. the lights will dim greatly, when the car is off, etc.
read these threads:
post6420641.html?hilit=battery#p6420641
battery-replacement-t569763.html
Thanks for all of your help!
that will be $50 sir.
jk
