A few rb26-25 compatibility questions
ReganGTS25T
Car: Skyline ECR33 GTS25T
as some of you might know im geting rid of my 607 rwhp rb25 and goin to build my rb26, i bought the rb26 without the cas tps alternator and hydro pump, i noticed right away that the hydro pumps bracket is diffrent soo im guessing that wont be the same, so that leaves the alternator and the cas is it the same ?
Cjmartz2k
Car: Hunting for a '89 GTR now
Depends on the ecu more than anything else. What will you be using? if the CAS fits on the cam and you are using the same ecu, it'll work. Also, older 26's use the same cas as series 1 rb25's and rb20's for that matter.
ReganGTS25T
Cjmartz2k wrote:Depends on the ecu more than anything else. What will you be using? if the CAS fits on the cam and you are using the same ecu, it'll work. Also, older 26's use the same cas as series 1 rb25's and rb20's for that matter.
cmon chrisssssssss you know i roll with the haltech platinum sport 20000 f*** my engine is an s2 i just need to know if the s*** fits
gawdzilla
Car: none
what's a hydro pump? water pump? i thought they share the same water pump.
CAS should be the same unless you have a very late model engine with the black plastic CAS. that one has a different drive i believe. all the earlier CAS'es should be the same
ReganGTS25T
hydraulic steering pump :D, well my car is a 1998 r33 gts its the oldest non neo rb25
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
the powersteering pump will be different between the two motors. As well they're pulley's are offset differently.The pump itself should be able to swap over without a problem but since the pulley will be offset incorrectly you'll want to switch your harmonic balancer to match the powersteering pump.
The CAS on your previous motor should have a star and half moon input drive see if they match up, if they do you're good to go.
Alternator will interchange over.
TPS may be different, but would need to confirm.
This is given neither engine is a R34
ReganGTS25T
Coolwhip wrote:the powersteering pump will be different between the two motors. As well they're pulley's are offset differently.The pump itself should be able to swap over without a problem but since the pulley will be offset incorrectly you'll want to switch your harmonic balancer to match the powersteering pump.
both engiens are r33 engines im prety sure the bracket that holds the steering pump is diff on the rb26 ill check now though and if the pulley si diffrent cant i just get an rb26 pulley kit? that comes eith the alternator water and hydraulic steering pump? tanks for your help btw
Coolwhip
Vendor
its the offset of where the pulley ends up, either thats done with the bracket, the pump, or the pulley itself. Ultimately, requiring the harmonic balancer to be aligned with where ever the power steering pulley ends up. Hope that makes sense. But overall, i doubt that the pulley swap will change the offset, I think it's more of a pump issue being different.
ReganGTS25T
so basically im f***ed
gawdzilla
Car: none
if you use your 25 crank pulley and 25 pump it should work.
Coolwhip
Vendor
gawdzilla wrote:if you use your 25 crank pulley and 25 pump it should work.
This is the easiest solution in which I was trying to broadcast across.
If you use the 25 pump, you'll need the 25 balancer. If using the 26 pump you'll need the 26 balancer (R32 pump and balancer differ from the R33/34 parts).
Cjmartz2k
Well Regan, if you can't find stuff you need over there, let me know, although you never really find 26's in junk yards over here.
But agreed on the what they have been saying. Bolt all the 25 gear up to it and it should work just fine. You just might have to swap a few brackets and balancer along with the actual pumps and stuff.
ReganGTS25T
Cjmartz2k wrote:Well Regan, if you can't find stuff you need over there, let me know, although you never really find 26's in junk yards over here.
i <3 you chris when are you goint o get aim msnger ANYTHING other then your gay email account
ReganGTS25T
if you can get me the littl thing that goes above the itnake manifold that controls the itb's with the tps when you come to peru ill get you laid thats right
Cjmartz2k
I usually only get online when I'm at work but not in position actually talking to airplanes. No messenger allowed on those computers, but I might try and get one working at home. Just don't use it much though.
You just need a TPS or something else? Circle it in photoshop or something in a picture and post it up. I can probably get it.
ReganGTS25T
Cjmartz2k wrote:I usually only get online when I'm at work but not in position actually talking to airplanes. No messenger allowed on those computers, but I might try and get one working at home. Just don't use it much though.
thats what i need man its really hard to type somthing up with a mouse
