Yes the bushings in the knuckles can go bad, what effects it has I do not know. You can buy poly or pillowballs to replace the factory rubber units.Infinitiguy19 wrote:The bushings that are part of the rear hub. I know there is a another name for it but I can't think of it at this point. A few more questions if you don't mind:
When cold and so far only when cold or cold enough to see the exhaust smoke, I see a bluish/grey smoke for about 5 maybe 10 seconds top's. Is this normal at my current millage or should I start wheeling over the engine hoist for a engine rebuild?
Is the engine gusset (The thick metal joint on the engine and transmission) supposed to only have one bolt securing it to the engine? It seems like there is supposed to be two bolts on each side of the engine but its missing one. I hope you guys know what I am talking about.
Is there supposed to be a cover on the starter because there is a gaping hole on the side of the starter?
The bushings in the knuckles (That's the name I was think of) are about a three hour job each side according to All Data. I might take a pry bar and see if there is excessive movement in them.IThaJ0kaI wrote:
5-10 seconds of smoke with 150K+ miles isnt terrible, especially when cold out.
Yes the engine bracket is supposed to have 2 bolts, but its roll is very minor. As long as it is tight on there, you shouldn't have any issues.
Can you take a picture of the starter? There is a hole in the mount on the block for it, its to get 1 of the main bolts out.
Do you mean while the car is running, or off?Infinitiguy19 wrote:Yet another question: Are the rear wheels supposed to spin in neutral while on a lift? Is that even normal?
Sounds like watching p0rn with your hands tied behind your back...Infinitiguy19 wrote:One more question: Am I hurting the car by keeping the engine under 2000 RPM's? I can't remember the last time I did a Wide Open Throttle (WOT) run.
Q451990 wrote:Sounds like watching p0rn with your hands tied behind your back...Infinitiguy19 wrote:One more question: Am I hurting the car by keeping the engine under 2000 RPM's? I can't remember the last time I did a Wide Open Throttle (WOT) run.
I put some serious thought into this. And to buy your Q I would just make one good one with the two or put your Q's parts into mine. But then I thought about buying a cheap four cylinder car which would be smarter. But then when would I find time to drive mine when I work so much. I hardly take care of it as it is. At least your honest about not being easy on your Q.BCC93QT wrote:Paul, I can get 1250 for my Q if I trade it in toward a car here at my dealership. If you want it for 800$ its yours. Engine and transmission are strong @ 290k.
Yes this is normal, you should be able to stop the wheel from spinning by hand. If not, then something is wrong.Infinitiguy19 wrote: The rear wheels spin in the air when the automatic transmission is in neutral and the engine is running. Is that normal?
Infinitiguy19 wrote:I put some serious thought into this. And to buy your Q I would just make one good one with the two or put your Q's parts into mine. But then I thought about buying a cheap four cylinder car which would be smarter. But then when would I find time to drive mine when I work so much. I hardly take care of it as it is. At least your honest about not being easy on your Q.BCC93QT wrote:Paul, I can get 1250 for my Q if I trade it in toward a car here at my dealership. If you want it for 800$ its yours. Engine and transmission are strong @ 290k.
Also my car shakes like crazy sometime when accelerating or when the torque converter is locked up. The engine RPM's also fluctuate which is why am inclined to believe its the torque converter. Is it the torque converter or the transmission mount? I figured I would replaced the $130 transmission mount first then use my spare torque converter if that doesn't fix the issue. I hope my spare torque converter is good as the car it came from was towed with the rear wheels on the ground and the engine not running. I am sure it is as the torque converter is bolted to the flywheel and splined to the input shaft of the automatic transmission.
