GorillaClub »
https://forums.nicoclub.com/gorillaclub-u11667.html
Thu Mar 02, 2006 8:17 pm
OK guys here it is...
I have had my SR for about 3 months now, just driving it around stock with a front mount and boost controller and a couple other upgrades but nothing to serious.... well its treated me fine and I really ahvent had a chance to touch to boost controller front its stock wastegate setting so I have been running about 9 to 10 pounds (spike) and then tapper to 8 or 7 by the end of the gear, well when I adjusted it the other day my boost wouldnt go any higher then that, no matter where I set the controller it stays the same, and I know everything is hooked up correctly.
Second, at around 5500-6000 Rpm my car has a harsh rattle sound, but not something normal like a loose clamp or bolt its more of a vibration you can hear if you know what Im talking about, its the best way to describe it, what is this.. also it seems to be coming from the passenger side, under the hood.
Third the car seems down on power, it does spin the tires from the 1-2 shift near as long as it used to, and it just seems a bit more sluggish.... No i understand reading all of this the obvious reason would be my turbo is going, but could there also be other reasons or things I should look for to confirm a problem! Thanks
