A few questions about my 97Q:
1. Is there a setting (not documented) that would have the doors lock automatically? My doors have to be locked manually using the lock/unlock switch.
2. Is there another setting (again, not documented) that would beep the horn in addition to flashing the lights when locking the doors from the remote?
3. I plan on changing the oil and filter every 3750 miles. Should I be using a synthetic? If I use the synthetic, can I extend the interval to 7000 miles? I don't drive alot, so the changes will most probably be done on a time basis rather than a mileage basis.
Thanks for all your help,Steve
