lrb_2000 »
https://forums.nicoclub.com/lrb-2000-u28436.html
Sun May 25, 2008 8:38 pm
So I finally got my engine in and started.. It surprisingly started right up. But I noticed coolant leaking down the side of the block, coming right out from where the head and block meet under the intake manifold. I took off the intake manifold and turbo manifold etc..
My question is.. the head gasket is leaking obviously, the head has a few scratches in it that I can feel with my fingernails. It was resurfaced by the guy that built it but it must have gotten scratched in shipping it. Could this cause the coolant leak? There is water in the oil i'm pretty sure, so I guess I just answered that one. Also, when I installed my arp head studs they all seemed to be different lengths when installed. should they all sit at the same level when tightened into the block? and lastly, if I go with a cometic headgasket is there anything special to do to it so ensure it seals right? I had a oem felpro headgasket before. Remember, this engine has only been ran for about 5 mins, everything is new. Maybe I should just reuse the headgasket...?
Here's my plan. Get the head resurfaced, get a cometic gasket, reinstall the headstuds, and it should be good to go?
