kapower06 »
https://forums.nicoclub.com/kapower06-u18983.html
Wed Sep 07, 2005 10:31 am
My first question: If I plan on only running around 5-6 psi from a t3 super 60 do I need any kind of fuel controller? Also I already have a walbro pump and a adj. rising rate FPR which i could use. But If not thats One less thing that could break.
Second Question: Since im either going to use a RRFPR or just stock ecu with a little more fuel pressure, do I need to recirculate my bov? Im using a stock s13 smic with the stock recirc. valve?
Thrid Question: About how much hp could I expect from this set-up? a new t3 super 60 around 6 psi, through a s13 smic. on a Single cam with a PDM c404 cam and around 165 compression across all clyinders? I will be happy with only 180-220rwhp until I learn to use rom edit or live edit.
thanks alot -Jake
