slownslurious »
https://forums.nicoclub.com/slownslurious-u29303.html
Thu Jun 09, 2005 8:52 am
Instead of the 240sx output shafts, which are hard to find, you should be searching for the J30 ones, which are in every junkyard around. Only certain years work and I can't remember which ones, but you should be able to locate it with a search for VLSD output shafts or something like that, I know its been covered in other forums so it should turn up quick. If you still can't find these let me know, there are dozens of J30's rusting away in yards here in houston.
I had a big problem with my car hopping, and I installed subframe spacers and stiffer rear springs and it help a lot... although I also installed a sway bar at the same time so I can't say for sure which one cured it. All 3 would probably help, but I'd say the subframe spacers are probably the cheapest and easiest and most effective cure. For the paintjob- sounds good to me, I have a video of a 180sx painted like that and it looks pretty hot.
sorry I can't tell you much about your fuel issue, check your fuel filter and your fuel pump/pressure. Is it happening even with a full tank of gas? might want to check the gas sock too though thats hard to clog. Do you hit it at 4500 rpm all the time or does it vary? Is your ecu throwing any codes?
