Chaotic_Warlord »
https://forums.nicoclub.com/chaotic-warlord-u26051.html
Fri Feb 18, 2005 9:00 pm
Ok as I stated in my original post I'm new and I hate to ask stupid questions, but honestly it would take me forever to read every post in here to find the answers I'm looking for, so please don't flame me. I know most would say that the sr20DET is the way to go, other would say that turboing the KA is just as good then there is the RB crowd. Having said this I will state my opinion...yes the SR is tried and true and while you may get a larger parts selection there is no replacement for displacement... as far as the RB goes its a Skyline block so it's a more expensive option, one that I can't afford. Having said this I have a few questions.1) The s12 200sx came to america with the VG30 block found in the Z32 300ZX so has anyone swapped in a VG30DETT from the 300Z into the RPS13? I would assume it would fit since the RB26DETT fits but what would be the wiring situation, wouldn't you be able to just rip the whole asembly (Engine block, mounts trans wiring harness and ecu) out of a wrecked 300Z and drop it into the 240sx or would it be more than that? (I'm not mechanically stupid so I do know the whole process of an engine swap is more complex than that)2) Having stated that there is no replacement for displacement, would it make more sense to build up and turbo a KA block or doa full SR swap and install the displacement up package from TODA? 3) I know it's all up to personal preference and bank roll but who makes the best internals for the KA? I'm mostly wondering about the pistons, rods and crankshaft. I intend to build up my block so that it is seriously bulletproof before I do a turbo install, and being that the internals take the biggest beating under boost it only makes sense to build up before boosting an old engine.4) Stupid question alert...aside from the drive change RWD to FWD what is the difference between the JDM SR20DE found in the non turbo Silvias and the SR20DE found in the 200sx SE-r and Infiniti G20?5) FInally, in the event I'm only able to find an automatic trans RPS13 can anyone tell me a rough estimate on doing a 5 speed transmission swap (parts and install) I could probably find a transmission in a local junkyard and just replace the clutch and flywheel for around $800 (most of that is the expense of a stage 1 clutch and Fidanza flywheel) and I've read the FAQ on how to do the swap, just don't have the space or tools to do it myself.Again please don't flame me and I have already started reading up to try to find the answers myself. Thank you in advance for any info you guys give me.
