Thanks Don. That fact that it worked on multiple Infiniti's is a good sign. I do like the StartSmart feature as that would take care of me leaving class (being a mile or so from the car) and still being able to start it.DoN_BLaZe34 wrote:Installing a remote start in these cars in not that difficult provided you get an installer that knows what they're doing. I can't speak for what "the best" remote start is but when I had my 45 I had a Viper 5501 in there I believe along with the SmartStart add on. I opted for this system specifically as I didn't want the alarm, just the remote start but also I wanted the one mile range on the remote IF I chose to carry it. I never carried the Viper remote with me, I only used it in the morning to start my car. Any other time I would use my phone which is Galaxy Note 3. Prior to this, I had a Droid RAZR then Droid Razr Maxx. I also had this installed in my FX45, again with no issues.
The moral of the story is find a Viper authorized dealer to do the install (if you go that route), this way if you run into any issues you're covered and can simply take the car back.
Yeah, you definitely have to vet out installers. I'll be specifically asking if they've worked on newer Infiniti/Nissan products.TDot wrote:The problem isn't finding a viper dealer/installer, the problem is finding one who has worked on an M or G. I'm not one that believes that just because you installed on five other types of cars you can install on mine. The wires you may tap on other cars might cause issues on mine. If I were you I'd go to an infiniti dealer near you and find who they use (the mechanics would probably be more willing to spill over the service reps) to install remote starters, that's what I did. But it won't be easy, you got to be real slick with your questions and how you talk lol. And if you're the slightest bit hesitant, install it though the dealer. It will probably be $100 more, but it will be warrantied through them...$100 piece of mind.
I put some belt dressing on the other day after I took it off the lift (after tightening the belt) and it was still squeaking. Am I right in that it's the small belt? The squeaking will stop IMMEDIATELY if I turn off the AC/lights, etc.svard75 wrote:Have no idea about question 1 there Ilya but on question 2 did you use any kind of spray on or near the belts. Try just a bit of belt dressing just to quiet the squeal down. If you accidentally got grease then it'll eventually burn off but you can maybe clean the belt a bit again using belt dressing and a toothbrush. Before you installed the new belt were all the pulleys cleaned. I prefer to use dish soap diluted in water and a toothbrush.
I have no idea whether this is compatible with our cars, but note that it is bluetooth only, as far as I can tell.Larz wrote:I have been unable to find any evidence that it is compatible with our Infiniti M models and have found NO reviews from M owners for this specific model. Here is a link to the Viper VSK100 on sale:
http://www.sonicelectronix.com/item_890 ... SK100.html
The AC is alone with the smaller belt all else is on the larger belt. Tighten it more then. I believe my belts squealed for awhile brand new. I kept adding belt dressing to both. Use a toothbrush while the engine is running and not close to any pulley lol.IlyaKol wrote:
You might also check your alternator bearings. This may be unlikely, but if the squeak is because the pulley sticks at high speeds and the belt is slipping, you'd want to fix the problem instead of the noise.IlyaKol wrote:The squeaking will stop IMMEDIATELY if I turn off the AC/lights, etc.
Thanks man.dball wrote:Hey Ilya, i forget which exact version i went with, but i got a directed smart start installed on my M, i should of showed it to you at the BBQ works great, runs through your cell service and is controlled through your phone. no limit to distance or interference. i think its like $20 for the first year then like 150 for 3 years or something like that... ill let you know more once i figure out which module i got
