Would a leaking injector or a stuck open injector make a noise such as blowing wind/hissing? I'm getting this noise near the #1 injector.WDRacing wrote:I agree, locktite will work, or you could hit the gym and quit being a whussy.
The oil will be black quick, like a day of driving quick. The smell of fuel though...I've smelled fuel soaked oil, it was a leaking injector causing it, we actually lost the motor, well we lost a cylinder because it stripped the oil off of the walls of that cylinder.
Check your compression for sure. Are you sure its fuel? Oil stinks...
WD
Hmmm start up is fine, and driving is perfect. I do not have a fuel pressure gauge, only boost and the SAFC-II. Sometimes I get white smoke when I start her up/idel, after driving it goes away. I think that's just the from the cold temps up here.WDRacing wrote:I've only heard them tick, but thats normal ops. A leaky injector can make start up very hard somtimes, or you'll billow smoke after startup. Do you have a fuel pressure gauge? Try a leak down test.
WD
I agree if we are talking about any hardware on the exhaust side of the turbo, including the manifold and downpipe. However, the intake side should hold up fine. Loctite would also burn off on the exhaust side. You'll need a mechanical locking system - mechanical locknuts, safety wire hardware, or stage 8 or similar hardware. And you can forget about serrated or belleville washers. They hold longer, but I went through a bag of them and none of them held in the long run. I used a set with the mechanical locknuts as well, but only because I felt I might as well since I already paid for them.DammitBobby wrote:Lock washers won`t do crap for holding turbo bolt. The heat will cause the washer to flatten out and then the bolts will loosen up.
