Beancooker »
https://forums.nicoclub.com/beancooker-u42602.html
Wed Nov 28, 2007 6:41 pm
Yes, you could activate the solonoid to open the butterflies earlier. It has to do with vacuum. You would need to have a vacuum booster to attain this. Follow the tubing, and you can probably see where it needs to be.
You have a 4th gen Maxima, so the headers won't give you a whole lot of gain. Your best bang for the buck is a Y-pipe, and it will give you between 10 and 15 HP.
Had a warp speed on my Max, and it was okay. I needed to have additional work done, to fix the banging.
Okay, you can't add up the HP numbers like that. You need to be realistic about this. The most you can look to gain from just exhaust is probably about 20 HP max. If you were forced induction, then exhaust would make a much bigger difference. Think of an engine as an air pump. The more air in, and out, the more HP you get. If you can get a lot in, but not out, it will cause a loss in HP. If you can intake 500cfm, but can exhaust 750 cfm, you're not losing any power, but you're not gaining anything over being able to exhaust 500 cfm. Hope that made sense.
Oh, no need to type all crazy in the title, or have everything in bold. I'm not that old yet.
