Checkered-Member wrote:Background:
I’m building a turbo kit from nothing, I’ll be running 9psi with a T3/T4 on a stock KA24DE. I have a place that will do a custom manifold, intercooler piping, and down pipe. 1. What is the difference between a $100 wastegate (no brand: eBay) and a $300+ wastegate (HKS, ect), I mean they perform the same function, so what am I missing here?
2. On the same topic wastegate come with a spring I see on eBay listings like 8 psi spring how do I get a 9 psi spring, do I need to go threw the seller, manufacture, after market?
3. When doing intercooler piping what material to use? Steal, Aluminized Steal, Stainless steal, Aluminum, others?
4. Right now I have a 2.25 crush and bent exhaust with a street magnaflow muffler, will this seriously hinder performance? I know I “should” get a 2.5 mandrel bend. But will my current setup kill my whp?
5. Intercoolers are they all pretty much the same? Or are there specific things I need to look for/stay away from?
6. Do I need a new fuel pump on 9 psi (I know it’s recommended, but do I need it)?
1) A better quality wastegate will improve response, be more accurate, and flow more air. I say improve response b/c the wastegate actually has to start opening a bit b4 the boost level is reached. A quality(TIAL) wg will open later than a cheap one and still serve it's function.
2) TIAL will get you a 9lb spring if you want it...or u could buy a boost controller
3) Alum or mild steel(like aleph said)
4) I would reccomend at least 2.5" mandrel bent. a 2.25" crush bent will probably restrict your exhaust and cause your turbo to lag more than it should.
5) Exact quote from aleph...water cooled intercoolers are always an option but they are mucho $$ and mucho custom stuff.
6) Yes, I wouldn't trust the stock pump in prime condition over 4psi. a walbro is 90-100 bucks..why risk blowing a 1500-2000 dollar investment?
