A few questions about the lifts from 4x4.com
Natedogg1701
Car: 2003 Nissan Pathfinder SE
just a few questions when these lifts offered by 4x4.com are installed. do you need to replace your track bar and trailing arms? and do you have to change tour swaybar endlinks to longer ones? i mean ill spend 700 buks on a lift kit, but not when im gunna spend another 500 or more on additional parts.
fueler
Car: 2 Nissan's
2 BMW's
no you dont have to change any of that stuff withsuch a small lift (2") you should extend track bar and trailing arms when you go 4"+
and itsnot even required, you can drive down the road without replacing that stuff but your axle will be in a funny spot and off to the side.
Natedogg1701
but with the factory suspension a 2" lift will be no problem, with the bigger tires and higher ride height the suspension wont be too soft or not strong enough to handle the lift? only reason im concerned is because a buddy of mine lifted his blazer nd he didnt do any other suspesion parts except springs, shocks, ect.and he rolled it because the rest of the factory suspension couldnt handle the lift.
fueler
Car: 2 Nissan's
2 BMW's
pathfinders have a much lower center of gravity. even with just 2" lift springs and the rest stock, you could spin donuts all day long and you will never come close to tipping over.
Natedogg1701
nice thats what i want to hear, have you lifted yours? i planned on getting the whole lift kit, struts, shocks, and springs, and to lift the front i think i need new struts all together anyway, beasides using spacers i mean.
Natedogg1701
actually i saw one of your post in a different thread, you and empty V have an oem lift? how much of a lift does it give you and where can you get it?
Pwnin O'Brien
They have the 1.75" OME (Old Man Emu) lift. You can find the lift at the following page: http://www.rocky-road.com/pathfindersus.html
fueler
Car: 2 Nissan's
2 BMW's
whats funny is the white pathfinder pictured on that site, belongs to a member of http://www.4x4parts.com and its running a AC 2" lift, not the old man emu lift !!
i recommend http://www.ruggedrocksoffroad.com for Old Man Emu,
rocky road actually has messed up part #'s and descriptions and they are selling weaker lifts under the guise that they are heavy duty. ruggedrocks has everything on point and on deck!
KyooX4
Car: 2001 Infiniti QX4 4wd
So emus only give you .5" to .75" of lift, not 1.75"?
Pwnin O'Brien
Yeah, what the hell? So there is no OME lift over 1"? So the AC lift offers the biggest suspension lift? I wish there were an easily accessible SFD for the R50.
fueler
Car: 2 Nissan's
2 BMW's
the specs arent very accurate.
mine are supposed to be 0.5" on paper but i got closer to 1.75" in real life
Pwnin O'Brien
fueler wrote:the specs arent very accurate.
So you have the 0.5" OME springs but you netted a 1.75" lift? So if I were to use the 1" OME springs, could I expect more lift (like 3")?
KyooX4
Sheesh, I'd probably just fork over the extra money and get the AC lifts, just so I know what I'm dealing with...
fueler
Car: 2 Nissan's
2 BMW's
the AC lifts say 2" but you actually get 2.5" some have gotten 3" out of it.
Pwnin O'Brien
Why does the AC site say that an aftermarket wheel with a 3.75" negative backspace is required with the lift installed? Is this actually required?
Natedogg1701
the rockyroad site is actually more expensive than 4x4.com. and personally i'd buy the lift from 4x4 just because they use GR-2 struts and bilstein shocks. but on 4x4.com their is a 765 dollar and a 790 dollar kit. the 765 dollar kit uses bilstien shocks, and the 790 dollar kit uses rancho RS9000KL shocks. anyone know which shocks are actually better?
fueler
Car: 2 Nissan's
2 BMW's
Pwnin O’Brien wrote:Why does the AC site say that an aftermarket wheel with a 3.75" negative backspace is required with the lift installed? Is this actually required?
no, lots of people run stock wheels which have 4.5" backspacing!! its when you upsize the tires that you need less backspacing !!
KyooX4
This is a bit confusing to me. Let's say I got the AC 2" lift, and put 265/70-17 (31.6") tires on my stock 17" QX4 wheels. Would I have problems?
burns9189
i was wondering the same thing a have a 02 pathfinder with 17 inch rims would 265/70-r17 need new rims
Empty V
1982 Chevy Corvette C3 Shark
I think you guys would be fine. You would probably have to trim a little plastic but that's it. I've got the EMU 922HD springs and I got between 1.5"-2" of lift. I had no idea people were reporting up to 3" with the AC springs. I wonder what they settled to. If they're getting over 2" I might change over!
Billy
burns9189
and ome offers a kit with out front struts does that mean i can reuse my front ones? i asked the guy at rocky road and he said it would be ok .he also said i should buy a trim packer kit everything will come out to 554 after shipping
Natedogg1701
.....so ya, bilstien shocks or rancho rs9000xl shocks, which ones better?
burns9189
rancho rs9000xl shocks with old man emu 1.75 coil springs. the guy at 4x4parts said itd work and stock front struts
Natedogg1701
just want to know because i plan on getting my lift from 4x4.com and i want to know if i shud get the kit with the rancho rs9000xl's or the bilstein's. that ome kit is iffy to me, and seems more expensive. also im not keeping factory anything, just gunna do a complete lift kit.
KyooX4
You don't have to buy it as a kit. You can buy the coils by themselves and get the shocks and struts cheaper somewhere else.
