A Few Questions About My S13 Fastback
foulplayer
I just recently bought a 1992 240SX FASTBACK SE, and i have a few questions about it. If you can help, then that would be great.
:confused: 1. The car idles real badly when the A/C is NOT on. When the A/C is NOT on the needle bounces back and forth from 500RPM to 1000RPM. When the A/C IS on, it idles with no problems at 1000RPM. Can anyone make sense of this?
:confused: 2. I have never owned a 240sx before, and i was curious, even though the car is in gear (M/T) does your shifter have alot of play in it, left to right? Mine sure does.
:confused: 3. What is the easiest way, to find out if my car has Hicas, super Hicas, or no hicas at all? I got underneath the rear end, and was looking but wasnt for sure what to look for.
Any Help Would Be Greatly Appreciated :)
ThanksDanny
SloS13
didnt you post this in another forum? Thats a no-no
llamabeta
1) I point you to the search button. Search for "bad idle, hesitation, bogging and etc" The reason I mention these words there a few things that can be wrong. Vacuum issue, idle screw, MAF and etc. Most of those related to idling issues and etc have a list of things to check and can help to narrow the cause down.
2) I own a 92 Coupe. Though I dont know your defintion of "alot". I find my rather comfortable and well weighted. Perhaps yours is far more worn than mine. I would like a shorter throw.
3) If you know what a tie rod looks like it will be easily identifiable. Looking at the service manual. It bolts to the rear toe link. You should see a shaft extending past the rear tower and in towards the subframe into a cylinder (rack).
The rods look similar to this (These are front tie-rods):
GroundZero
foulplayer wrote:I just recently bought a 1992 240SX FASTBACK SE, and i have a few questions about it. If you can help, then that would be great.
ThanksDanny
1) there are lots of things you can check out do a search, thats the best way for you to find solutions to your idle problem, it's all a process of elimnation when it comes to idle problems.
2) mine does i don't know if thats normal or not though
3) i have a 1991 Super HICAS edition, next to the button to activate the rear-glass wiper there is a little hicas warning light, on the sides of the car there will be a stickers that say Super HICAS, i beleive there is a way to check using the vin but i don't know how.
ch1873857
ok does your car shake at idle, mine did and you said something about the shift knob, yeah mine shook a lot, like uncontrollably. i fixed my problem by raising the idle screw and checking all vaccum lines, i had one split(one from the intake to the valve cover) i wrapped it in eletrical tape but i got a $60 dollar intake off ebay and solved that problem, other than that it stopped without really adjusting or fixing anything, but hasnt done it since
ricebike
2002 Quest
2005 Altima
when i had my car inspected by a private garage 2 months ago, the guy told me that the shifter is kinda sloppy... <shrugs> this is my 1st manual car soo I don't know how it's supposed to be either... any south jerzee peeps w/ a stick shift show me how's it supposed to be? thanx
