mtzgr777 wrote: FOUND CODES P0340 (CAM SENSOR), P0325 (KNOCK SENSOR), AND P1705 (THROTTLE POSITION SENSOR). BESIDES THE FAILED SENSOR VEHICLE MISFIRES DUE TO BAD INJECTORS. TRANSMISSION ALSO SHUDDERS.
DIAG DIAGNOSED CONDITION AND FOUND MULTIPLE ISSUES. RECOMMENDED PERFORMING NO WORK TO VEHICLE AS IT WOULD EXCEED PURCHASE PRICE OF VEHICLE.
-mtzgr777
Actually from '94 or '95 up the key should be on... Nissan switched the injectors to a switched circuit at some point around there. Or you could just read the resistance through the other connector that feeds the positive voltage to the injectors.goody90q45 wrote:For Fuel Injectors- Key off.
94-96 injectors are all the same and are tested with the KEY OFF...Q451990 wrote:
Heath
If thats the case then this part of Q45.org should be removed so others won't become confused.http://q45.org/ohminjectors.html wrote:On 1995 and later Q45s, you may need to turn the key to "on" because the injectors are on switched power.-JG
The correct way to do it is to purchase the complete "under-plenum ultimate kit" from Joe and replace everything under the plenum.....all hoses,gaskets,knock sensors and harness,etc are included in the $900 kit and labor will add aprox $600 bringing total cost to $1500.......anything less just creates further problems and repeat labor. This has been discussed over and over and over on Nico for years,and proven by those who try to take shortcuts to save $$$ over the years.mtzgr777 wrote:Are the KS and Injectors somewhat near each other, so if I do have it fixed, the labor wouldn't be too much more for both? I just wish some mechanics and or dealerships actually respected my car. All four places I've been to say "It's not worth fixing up something that's worth so little" or "That's why these cars are so cheap, no one can afford to maintain them."
That doesn't sound too bad to me. So you're saying that entire kit will only take a mechanic about 6 hours to put in? Is that for someone who's worked on Vh's many times before or any mechanic?qship96 wrote:The correct way to do it is to purchase the complete "under-plenum ultimate kit" from Joe and replace everything under the plenum.....all hoses,gaskets,knock sensors and harness,etc are included in the $900 kit and labor will add aprox $600 bringing total cost to $1500.......anything less just creates further problems and repeat labor. This has been discussed over and over and over on Nico for years,and proven by those who try to take shortcuts to save $$$ over the years.
I wish I did toosilkysmoothjud wrote: I wish you lived close by, I'd do it for a couple hundred bucks and a case of beer. I can remove that plenum in about 15 minutes now.....
The codes you're getting are all related and it's probably one event that is setting off all 3 at the same time. My guess is the stealership didn't ohm test the injectors or KS or they would have told you which ones were bad and supplied the readings.mtzgr777 wrote:.....but if my car is saying that the injectors are bad, doesn't it mean they are, so what's the sense of testing them? (I'm not trying to be rude I just don't understand...)
Maxnix gave me this info wrote:Injector Replacement
1) Remove blue 15amp fuel pump fuse from fuse array near the hood pull handle.2) Start the car and let it die. Then crank it several more times.3) Remove the front plastic trim cover right in front of the plenum...3 10mm fasteners.4) Cut off the short length of fuel hose right behind the trim and drain the fuel rail into a container. You may even want to blow the rail out with compressed air at 30psi, but it's not necessary. Obviously you'll need a length of fuel injection hose to replace the removed one. Take precautions against fire.5) Carefully remove the metal harness clip from the injector's harness connector.6) Pull the harness off the injector.7) Remove the 2 screws holding the injector cap down. Careful, they're on pretty good and easy to strip. Some techs replace them with hex-heads.8) Remove the metal spacer from under the cap.9) The old injector can be pried and/or pulled out. Make sure you remove both o-rings. If you drained the fuel rail properly, very little fuel should drain into the intake runner. Whatever fuel drains down will end up in the oil pan and thin out the oil. 10) Place the new o-rings on the new injector and place a bit of grease on them.11) Push the injector into the fuel rail, orienting it like the old one, and being careful to not pinch either of the o-rings.12) Replace the spacer, noting flat-side orientation, and fasten cap down.13) Place the clip on the connector first, and then place connector on the injector.14) Install new fuel injection hose and replace plastic trim.15) Install pump fuse.
Make sure the engine idle's smoothly and keep an eye on the exhaust for excessive white smoke. If you get a lot of fuel drain down into the intake, don't crank the engine till you're sure the gas is out of there, and change your oil soon.
Maxnix wrote:Remove intake stuff --- bolts that connect to runners--on the rear Y hose just remove clamp on passengers side leave others on ,, use small pry bar (6-8") Pry Y hose end off --- usually comes off almost easy... and not hard to put back on either. Lift plenium up slighty at angle (higher side being the throttle body side ) remove remaining vaccum hoses.. Done!. BTY it's an hour or less to remove
Q45tech wrote:Fuel Injectors Warning very bad experiences with rebuilt injectors as all they do is change the bad coil [solenoid]and clean the already worn pintle so they leak ! Most rebuilt parts are designed to last just 1 year or 12,000 miles at best [for used car dealers to sell you a working car]. Only buy new injectors [$150 TJ] please so you don't have to pay the labor twice.
If you bought injectors and gaskets [plus plenum middle gaskets from TJ you might save $50x8=$400 plus $25 x 6= $150 labor or about $550. But while an easy but time consuming job, if you haven't changed 6 PVC, plenum water hoses, fuel and vacuum lines or checked knock sensor harness or sensors: be prepared to do at same time as you don't won't to pay same labor again [these extra parts are around $600]. Are you sure all injectors are bad? Usually just one or two unless really bad gasoline. The 12 ohm test will usually work. My 90 at 207,000 still has OE injectors but all hoses were replaced at 80,000 - 120,000 miles probably time to consider it again [they last longer in colder climates].
Any sensor input that results in a rich mixture can cause an injector leak code. The best way to resolve a code 45 on these vehicles in addition to the injector leak down test is to carefully check the Mass Air Flow Sensor, coolant and 02 sensors along with a fuel pressure regulator test. You said the fuel trim was running rich!
I have seen the internal seals on injectors fail allowing gas to seep through the injectors. Look into that as well.
Since each injector cost $150 plus the plenum removal charge $500 you don't want to replace unnecessarily. [$1700 total] A smart technician can if inclined examine the waveform [current and voltage] of each injector and determine a lot but will you pay $400-$500 [5x$80/hr]for some research on top.....very few of us are smart enough to predict the future [the week] of a component failure or say with any kind of certainty that another one will not fail soon.
The injectors are $160 x2 = $320 plus the rest of the job is removing the plenum, replacing them, and 8 new plenum gaskets plus all the hoses that usually break from age and putting things back together. We would probably charge around $750-$850 depending on what else broke [hoses]. This job has only about 2 hours of common labor with the full chain and guide replacement [$2500] and none with the simple guide replacement, however you should be able to get your plenum water and fuel hoses replaced for maybe 1-2 hours more labor. If you are paying to take the plenum off be sure to check the knock sensors and harness while they can be easily changed [$400]. Personally I would attempt to get the Infiniti tech to moonlight at $45-50 hour and buy the parts from TJ. That said are you sure you have bad injectors a ohm check not the Consult is the way to confirm this along with the power balance test, were your plugs replaced at 120k.
I have more info let me know if you need it.Q45tech wrote:Crank Angle SensorWe've discussed the intermittent connectors on the crank angle and MAF sensors. Over the last year we have found 2 intermittent crank angle sensors themselves. We are not sure if it’s the socket, LED or the photocell/amplifier pulse shaper module but the ECU is supposed to go into fail safe [allowing the engine to keep running somewhat] but it doesn't .......a new sensor seems to fix it....in any event the sensor is non repairable as yet.
You are correct 0802 points towards crank position sensor. Check the connectors to see if they're not corroded or loose. Infiniti calls it a magnet sensor & it's located near the flywheel. List $36.85 Cost $27.64
