BaliLover »
https://forums.nicoclub.com/balilover-u6785.html
Sat Jan 31, 2004 7:12 pm
My swap is completed, everything is hooked up, but I'm not yet on the road, the car is still up on 4 jackstands at the moment.
I have been running the car for a few days while I install things, and haven't had any major problems. Today I found a missing plug under the fusebox and I found its mate just hanging so I hooked the 2 together and went about installing my oil pressure gauge. I go to start the car for the first time in 2 days, and it throws a CEL. I don't remember it doing this before so I start to look around for anything that might have changed, and I found nothing, everything is still pluged in. I unplug the plug under the fuse box to see if that was causing problems and the CEL stayed on.
I figured I'd do the diagnostics thing on the ECU, so I pull the kickpanel back off and my heart drops. The pentometer that is usually metal and a sloted screw type isn't there, theres only a little white plastic phillips head about 1/4 inside the ECU housing. Oh well, just need a different screwdrive. I do the turn right, wait, turn left thing, and I get no flash. This is when I notice THERE IS NO LED IN THE WINDOW! Thats right, zip, zilch, nada, nothing, just an open window.
I yank the ECU out and theres a sticker on the side that says its a Nisssan Remanufactured ECU. I pull the top cover and find that theres what appears to be a daughterboard hooked up, and the back edges appear to be hotglued. There are 2 pretty good size IC chips, both labeled X38 1999. 10. 5 on the daughterboard. I look at the LED spot, and its 100% untouched, like there was never an LED installed, just 2 smooth silver dots. The Pentometer looks like it belongs from the inside, no signs of it being replaced or anything, unless they are superb at soldering.
So now I have a delima, has my ECU been tampered with to accomadate larger injectors or a different MAFS or something, and how am I supposed to check codes without an LED?
Next problem: I hooked up my boost gauge and I'm pulling almost 20lbs of vaccume, and when I rev the motor the boost goes up to like 5lbs, but it won't hold, it just drops back down to vaccume. I am unfamilar with turbos, so I don't know if this is normal when the car is in neutral, so I put it in gear (rear end is in the air) and tried it with the same results. Is this normal or is my turbo toast?
I also have 2 plugs, just outside the firewall hole that are going to nothing. I don't seem to have anything on the car or motor that would connect to them, and i think they are both 2 wire plugs.
I have pictures of the ECU and the plugs if someone cares to host them for me.
