Havent checked with multimeter,but i ground the surface down t bare metal where its grounded so im pretty sure its good. checked all cylinders,and they are good.all plugs firing.duffman1278 wrote:The rough idle might be a misfire, check to make sure your coilpack is grounded to a clean ground with a mutlimeter. Also, look into each cylinder to make sure your not flooding your cylinders. You might possibly have a leaky injector. And check to see that each spark plug is getting spark.
Used soapy water method for boost leaks. hmm,,, i didnt use the links for timing. i set it at TDC the andjusted to 10 and 12. put the chain on.duffman1278 wrote:Did you check for boost leaks using a boost leak tester or soup and water? Please don't say you visually inspected them lol As for timing, you did make sure the black links on the timing chain matched up with the mark on the cams right?
gonna go buy one tomorrow.duffman1278 wrote:For your oil pressure issue, why not try getting yourself an oil pressure gauge so you know exactly how much pressure your getting?
looked at it when i swapped out heads,and it looked damn clean to me. but i will pull it again and clean it!blinker_fluid wrote:1. iacv
All hoses are the way they should be. swapping out CTS after i finish this post!blinker_fluid wrote:2. check for kinks in the hoses, issues w/ cooling fan, cts maybe messed up
no dents in oil pan,cleaned pickup and changed gasket when replaced front cover.blinker_fluid wrote:3. oil pick-up and gasket, dented oil pan.
How do i see if it is working properly? when i let off the gas i can hear it blow off and recirc. im pretty sure i have the vacum lines connected properly. i have the one from IC pipe connected to wastegate, one from throttlebody to recirc/BOV nipple by stock IC,and 1 from toip of throttlebody to a T which goes to FPR ,and boost gauge. those are the only ones i can remember off the top of my head. if there are anymore where should they be? i also remember that the other nipple on tbody is capped off.blinker_fluid wrote:4. check bov make sure its working properly and vaccum lines are hooked up correctly.
So you recommend i take the front cover off again ,and do the timing that way? Do you,or anyone else know of another way to do it without pulling the front cover?Hijacker wrote:I'd be worried that your cam timing if off a tooth or two then, if that's the method you used. At the very least, I recommend people to count links if they're going to reinstall the chain like that.
Usually, I'll tell people to pull the front cover so they can visually line the chain back up with the marker links, but I do understand that is a major pain in the @ss to do.
guess i will be tearing into that tomorrow if i feel up to it. also while i was pulling out the front and rears seats and center console to clean them, i found the plug that goes into the dash by the ecu just about out. pulled it out to check pins,plugged it back in and now the temp gauge doesnt flutter. havent drivin it yet. dunno if that had anything to do with it or not.Hijacker wrote:I would pull the front cover (and the oil pans consequently) just to be absolutely certain that the crank sprocket is timed to the cams properly. You could count the links between everything, which would eliminate the need to move the chain around, but you would still need to pull the front cover to count the links that would be down near the crank. But the cam timing would really only account for the rough idle issue.
