DCaff300ZX »
https://forums.nicoclub.com/dcaff300zx-u136230.html
Wed Oct 25, 2017 7:44 am
Hopefully the OP passed on this car, as having bad turbos along with the other issues and normal Z32 maintenance issues needing address means this car would IMO be about a $4K value.
Turbo replacement is very expensive, and the 120K service definitely needed will cost another $800 (DIY) to $1.5K in most cases...possibly more if you get quality parts and have a Z guru available. The trans issue also adds a lot of cost and hassle for a car price that is not too much lower than the value of a good-running, properly maintained Z32. The value is around 7-9K for a manual trans Z32 with all of the above issues addressed (about $2K less for A/T cars), and does NOT include "rare" and "collectible" status that the car does NOT have, nor is valued for in any way.
Money can be saved buying maintenance parts from our many vendors (Z1, CZP, etc.) and have Z32 knowledge...but if not, things can be difficult as the Z32 is not a car most shops do well with.
My advise is to ONLY buy a Z32 WITH the 120K service done and receipts (very common, and well-known requirement for Z32-knowledgeable folks) available and with no known issues, as during ownership of a 23+ year old car you WILL be fixing things as you go. Mine came with everything above and more, but still lost a turbo and more about a year+ later and the whole car has been refurbished and updated/upgraded...keep that in mind as that is a pretty normal path of longterm Z32 ownership.
