A few pics of my vh45dett S13 project.
Discuss topics related to the VH41DE, VH45DE, VK45DE, and VK56DE engines.
Raxephon
Car: '04 RX8...for the moment...
canadiandrifter240sx wrote:Here are the latest pics
Nice work.
Where are you mounting the alternator or is there enough clearance for it in the oem location with shielding?
Also, what about A/C Compressor & P/S Pump? ( Are you going to use them, & if so, how?)
The altinator will be located beside the crank pully on thew right banks side, you can see the gap where it will go. It will be shieled.
I am not useing a/c as this will only be a weekend worrior and occasional daily driver.
I will not be useing the stock power steering pump. Instead I will be useing an MR2 electric power steering pump that will be mounted in the trunk/hatch and will utilize stock 240 super hycas lines to get the fluid to the rack.
Sil240
Car: Nissan S13 "The One Cam Wonder"
Nice work!!!!You V8 guys are CRAZY!!!!!Are you making a custom Intake Manifold for it??Dual TB's assuming?What kind of engine management?
Mettler
Car: HR31 GTS-8 coupe, VH41/45 Hybrid Transplant
Very nice work mate! Looks just how a TT setup in my car would look!
nissanman04
Car: '90 240SX, '95 Subaru Legacy
wow, super cool swap
slownslurious
and I thought my supercharged motor was gonna be badass
Here is one of the latest pics of the engine. Inatakes are not done but thety are wilded to the runners and bolted to the engine. Now I am shapeing the ports and then I will weld the TB's on.
hannibal
Car: Red Line to Glenmont
Gorgeous! And you can still use your strut bar.Can you post more pics of the runners/plenum?
Any idea how much lower your intake manifold is than the stock spider?
CD, I love you.
Hey Wes, I think this is homepage article SERIES material.
Would you and CD mind cranking out a few "episodes"?
USsil80
well i love this kind of project.. have you done any of the math for the intake runners or surge area.... loks awsome... have you set a time frame when you want to get it running...
Mettler
Hmmm, injector placement is interesting!.
USsil80
looks like the clutch slave cylinder is in the place where the brake booster should go.... mmmm. you going with a unboosted braking system
SuperHatch
Car: 96 TLC
canadiandrifter240sx wrote:Here is one of the latest pics of the engine. Inatakes are not done but thety are wilded to the runners and bolted to the engine. Now I am shapeing the ports and then I will weld the TB's on.
I tested the fitment of the short intake runners in the exact configuration you have them for my project. While it would allow the exact plenum setup that you have fabricated, I really did not like the injector placement. The injectors end up firing at a near 90* angle from the intake ports, whereas in the stock configuration they fire directly down the throat of the intake port at the back of the valves. No doubt your setup will work, but I dont exactly like the sacrifice in spray pattern.
Anyway, great work on your project and I look forward to seeing it when it's done.
You can use the same runners and have the injectors on the inside but then your surge tanks will be on the out side and unless hood clearence is not an issue then you would not want to do that. I maybe sacrificeing torque and spray patern with this setup but I am not going for max power. This car is going to be a drift car. Aslong as the fans think its cool and it has enough power to smoke the liveing *it out of my tires then I am cool with the sacrifices.
Also I will not have to modifie my hood at for this set up and I can keep my strut bar.
The clutch master cylender that you see in the spot for the brake booter is actually what is going to be operating my remote brake system, I have a braket built that holds a slave cylender over the rod for the brake booster and it is operated by the clutch master which is now attached to the brake bedal. I have not tested the system yet but I am sure it will work, I will more then likely need to put an adjustable proportioning valve between the slave and the master but we will see. I will be useing Viper brakes on the front of this car.
Oh yeah I forgot to mention that I got my custom made drive shaft. I ordered it from The Drive Shaft Shop.. real nice guy and they were very fast with building and shiping it, I had it in less then a week after ordering it. And it fit perfectly. It cost me $534 CAD shipped. I will post pics later.
Thanks for the coments guys I am glad you like it. More to come soon.
Thanks Chris
SuperHatch
Car: 96 TLC
canadiandrifter240sx wrote:You can use the same runners and have the injectors on the inside but then your surge tanks will be on the out side and unless hood clearence is not an issue then you would not want to do that. I maybe sacrificeing torque and spray patern with this setup but I am not going for max power. This car is going to be a drift car. Aslong as the fans think its cool and it has enough power to smoke the liveing *it out of my tires then I am cool with the sacrifices.
Oh I'm not denying that it'll work, and it looks awesome! I just thought it would be fair to point out the drawbacks as well. Good luck with everything!
Mettler
Top work man, I'd be interested in learning more about your remote brake system, because I'm presently not getting enough brake pressure myself, and want to run some kind of remote system like you've described... reckon you could please pop me an e-mail with a rundown of the hydraulic circuit ? :D
slownslurious
If you just want to switch to a racing style master cyl with remote mount resevoir you may want to check out racer wholesale and pegasus auto they both carry them in stock, thats likely going to be my choice.Twin MC's w/balance bar for the win.
Touch up work is not done but here is the pics with the TB's. I will do all the touch ups and polishing when the chassis goes to paint and the engine is out. Right now I am trying to get all the fabricateing done.
Here is a pic of the 2 of the ports.
USsil80
looks awsome right now...are youplaning to run the cold side though the headlight brackets????.... is there a aftermarket for these motors- as in of the shelf upgrades for inside the motor???... seems like the motor might need some help with the amount of work you are putting in
mould_jesus
Car: 1996 200SX SE-R (RIP). now a 1995 240SX
this i will be watching. religiously. and i actually might want to try this sort of swap on my S14, although i doubt i'd be able to pull it together.
i might be going with a Vg30DETT swap.i love the way a V-form looks in the bay of a 240.
mrzabala
Car: 93 Nissan 240SX SE Hatch
Awesome. Hopefully I'll get some welding practice soon. Keep it up.
It has been a while since the last update so I fugured i should post some pics and get you guys up to speed.
Things have been going slow and it does not look like alot has changed but that is because most of the work I have done recently is all the small stuff mainly to do with the intakes (IAC, PVC, Coolant lines etc...). All that stuff has been more difficult then I ever imagined it would be. I am trying to keep a clean cimetrical look and i makes things difficult....I don't want to just throw a bunch of hoses all over the place.
I have welded the stock IAC (cut off of the Q intake) to the back of the right bank intake runner and have used a Y hose to go to each runner and I have used 2 bolt on bungs taken from PS pumps the feed into the runners.
Then I took the PVC "T" found behind the coolant filler on a stock VH and welded it to the back of the thermistat houseing under the intakes.
I also moved a coolant temp sensor from the top of the coolant "Y" in the valley to the back side (this will be the one I use for the ECU and the one at the front will be removed). Does anyone know why there are 2of the same sensors? Is there only 2 on the TCS models?
I have also removed the coolant filler and rad cap then welded the hole shut and clocked it to come out under the throttle body.
Now I am going to finish the IC pipeing and start on the clean up. I still need to get 2 waste gates, 2 BOV's (HKS SSQV's) the rad and a clutch. Then I need to get the body blasted and painted.I could have the car done by the end of the month if I had all the funds but my budget is gone so it will take some more time unless I find a sposor to help out.......anyone know of any sponsors?...lol
Ok I will shut up now and post the pic's
Modified by canadiandrifter240sx at 10:00 AM 4/7/2007
USsil80
look s awesome ... bet you can't wait to open that girl up.... going to be a blast to drive....
SuperHatch
Car: 96 TLC
Lookin good man, interesting filter placement...
Florida240sx
Going to turn quite a few heads....if they can turn quick enough...
Ok so here is the latest on Bastard Child. I have almost finished all the IC pipeing, I just need to add the BOV's and weld up all the seams I am also waiting on a couple more couplers. The intakes are neer there final state and the top end of the engine will be buttoned up soon. I will be doing alot of work to the chassis and exhaust this week as I am on a 1 week lay-off. I had all intention of finishing this car by the end of the month but I am not sure if it will happen ..still alot to do. I still need the rad waste gates and a clutch.
Well here are some new pics.
I hav 2 of these and they will be placed just before the throttle body fornt viewside
All the pipe is aluminized exhaust pipe and I know I am adding more wieght then I want to but this is all I can aford right now and I can always copy them out of aluminum later once the car has proven itself. The BOV's are the 2007 model HKS SSQV. I guess tats all for now. I should get lots of work done this week so I will add more pics soon
Thanks Chris
David Steele
Car: S13 FastBacK
Good job.
Mettler
Awesome work mate, I am thoroughly impressed. It's great that in the Nissan V8 community, most of us try and do as much as we can ourselves! Your car's going to be brutal!
Miyabita_Y33
Car: RIP Sold 93 240SX Coupe Sold 93 240SX Coupe Daily 97 Infiniti Q45 Weekender 93 240SX Coupe
Im at a loss for words I like that ur keeping it Nissan and not making it interracial! lol
GOOD JOB
Return to “VH45DE / VK45DE / VK56DE Forum”
