HijackTheLeft wrote:I'm not sure if correct forum ettiquet is to break the questions up into different posts or to combine as much into one post to keep the forum clutter down, but I'm all about eliminating clutter, so here goes...
I bought a 1990 240sx about a month ago or so, and I love it. Maintenance on it had been lacking, so I got an oil change and I changed the plugs and wires. I posted when I first got it asking some general questions. Well, now I have more specific ones...
1. I have a short shifter on it, and it seems like if I shift too quickly, it takes a while for the transmission to upshift, and it really hurts my acceleration, as you can imagine. i've never owned a car with a manual transmission before, so i don't really know whats going on. Is this what a "slipping clutch" is?
2. The car has an Injen short ram intake, Monza 4-2-1 headers, Monza exhaust, true short shifter, Eibach Sportline springs (2” drop), and Tokico Blues shocks. It has new tires and no visible modifications other than being lowered. I like the stock look. It doesn't seem like it's much quicker than stock. That also may have something to do with the transmission. See question #1. But is there anything that i can do other than an all out engine swap or adding a turbo to get a few more off-the-jump horses?
3. i know this kinda contradicts the "I like the stock look" comment I just made, but I'd like to get some rims for my 240. Nothing too flashy... I'm leaning towards some gunmetal 5stars. They'd be the same color as the car. Whats the largest size that will fit without having to worry about the tires rubbing the wheelwell? keep in mind that it's been lowered 2 inches.
4. My center console has a hole in it. It's not where the ashtray goes, although its about that size. and its not where the lighter goes either. It's right next to all that though. What goes there?!?
5. I'd like to paint my headers, since they were originally white and are now half covered in rust. Is there anything that I'd need to know before I undertake that job? Like, am I going to have to replace any gaskets or anything? Or, is taking the headers off an extremely complicated procedure?
Thanks in advance for any help anyone has to offer.
Ok my friend, let's take these one at a time.
1) The thing with the transmission...make sure that the douche that had the car before you put GL4 gear oil in the transmission. Redline makes the stuff MT-90 and it has the frictional additives to allow the syncros to mesh properly. The GL5 which is probably in your transmission now corrodes the syncros and is too thick for them to engage properly...ie the lagging feeling you are getting. Don't feel bad I didn't know either until I read the fsm.
2) NA bolt-ons don't do a whole lot. I have nearly every bolt on you can think of including cams and ecu tuning by JWT. I might be at 160something at the wheels. Next step is boost...sorry bro these horses don't really wake up till you go forced induction.
3) Your wheels won't rub as long as the offset is correct. For the money 5zigen FN's are the best bang for the buck. For example I am running FN01R-C's 17X8 +25 front and 17X9 +35 rear with 235/40/17 front and 255/40/17 rears on my S14. They fit almost flush, don't rub, clear Z brakes, light weight, and look clean. I was in the same boat as you before I bought mine...everyone recomended them to me and it is by far the best money I have spent on my car. I would not run anything bigger than a 17" rim. It will make your car slower and is generally considered rice unless you can back it up with some serious whp.
4) I am assuming you have an s13, I don't really have an answer for you and I have no idea what you are talking about.
5) Painting the headers. If you want it done right you will avoid paint all together and have them stripped and ceramically coated. Even high temp paint will eventually burn off and make a mess. Like anything else in life, you get what you pay for. Do it right the first time.
Good luck
