roast wrote:Your car looks great and well put together! I like the creative position for your oil filter, I'm sure it makes oil changes a charm to perform...! =D
I have a similar turbo heat shield, have you considered installing a turbo blanket instead?
Thanks man...
I haven't changed the oil yet since I put the filter there, but yeah, it should be a breeze. I just mounted it where the little bracket that holds the CAS harness to the timing cover. Just removed the bracket, and slapped it on and zip-tied the hoses out of the way.
As far as a turbo blanket, I looked at them. Kindy spendy + don't really like how they look. The heat shield I fabbed up, believe it or not makes a HUGE difference in heat reduction compared to no shielding at all. I can touch the top of the shield after a pull, and it's just warm to the touch. I did add some of that gold stick on heat shield tape to the underside of the shield...so I'm sure that helps.
