Yes. Pull the connector off the ECU, get a meter, and read resistance between the severed end of the brown wire and pin #36 on the ECU connector. Don't just hook stuff up without checking where it goes to. You can seriously damage stuff if you do that.IAmAlive wrote: so I should just pull the floorboard and check the pins on the ecu connector for the brown wire?
Also, you're positive the black wire goes to the fuel temp sensor? Electrical errors can be very hard to fix and very costly.
